2641 - 2660 of 5295 Posts
DR 4000 is still no go...working on gear 1 3866 now
2488238
The average 11900K has SP 70+
Above average/good SP 80+
Really good / lotto winner 90+
Reactions: GanjaSMK
special tweak only engage for short range below 4000 to be safe
so added tweak to maximus tweak mode 2 for a much wider range without affecting normal XMPs: just choose mode 2 in below bios
this also has the eventual vtt voltage cstk1 asked for
m12
10700K/XII Apex/2x16 3200C14 G.Skill Bdie/RTX 2080
m12
What bios is the M12A bios based on? I assume 2103.
i9-11900K (SP89) @stock---4800Mhz-C19-28-28-48-1T----1.66V---SA 1.2V---MCIO 1.26V---Stressapptest----1 Hour
2488354
Trying mem OC on my SP89, turns out the IMC is a lot more finicky requiring specific voltage ranges for SA/IO to stay away from errors.
My SP85 would train 5066MHz C20 1T easily though it needs a little more voltage in the IMC and does away with 10-20mV less VDIMM at each frequency point. SP89 has a noticeable hard wall with memory scaling, mostly no POST up till 1.4V SA/IO for 5066 C20.
Might attempt 5066 C20 1T GSAT 1H on my SP85 soon.
Not New to Overclock.net
odd. i havent seen 11900k on gear 2 showing any diff on imc ..
maybe gear 1 or the upper ranges of gear 2.
interesting.
you verified your cpu sp on which board bro?
Z590-I STRIX 0704
Yes it's probably going to be the upper ranges of a daily OC.
interesting.
What would be regarded as safe SA voltage 24/7? Currently running 4 x 3733 CL14 with 11900k SP94 and 0707 BIOS on MH13. Was hoping to push it to 3866 for now before venturing into gear 2 mode.
Can anyone recommend timings to tighten for sub 40ns? Currently ~43-44ns in AIDA just using BIOS mode 2. Complete n00b with memory OC, I usually just follow guides and hope for the best with each new build.
Asrock timing config isn't reading timings correctly, any idea why?
2488356
Thanks
Thanks
get the updated one listed in the z590 oc formula mobo thread
Reactions: omeds and IronAge
