2881 - 2900 of 3988 Posts
That's an impressive frequency, is it with some kind of AVX offset? What did you use to test stability?
As for timings, you can generally assume whatever held for previous generations hold for this generation too (secondary and tertiary timings are very important). The only significant difference is that there's no RTL tweaking, you just enable Round Trip Latency in memory training algorithms and get a decent performance uplift.
I kept AVX2 and AVX512 offsets at 0, heard that was best for Cine R15 runs. Don't know if that's true but yea both AVXs are user specified at 0.
It's only a Cine R15 Single Thread run not a true stability test lol, my max Single-Core Per Core is 5.5 with this chip, 5.6 will boot but freezes.
Today it's 2-cores max clock so far 53 53 52 51 50 50 6c12t is looking good - I'm not even testing for an all-core overclock not with RKL - not competing - just setting up a responsive home office pc.
I'm only looking for stability with office work applications. : )
Thank you I'll enable Round Trip Latency and set up some previous ddr4 values. (y)
2489772
Discussion Starter · #2,882 ·
Discussion Starter · #2,884 ·
11900k @ 5200mhz all core
4300 ring
4400c17 tweaked
Stock 3090
Discussion Starter · #2,885 ·
Discussion Starter · #2,886 ·
Does the OLD Optane 900p work on Rocketlake?
4k random [email protected] QD=1 says yes :D
Can't find "Round Trip Latency" in the Apex XIII bios, is it in the Extreme Tweaker main menu or a submenu? Thank you.
This is the best I got so far. ho hum dropped the 11600K clock down a bit.
4800 18 18 37
2489809
Facepalm
4800 18 18 37
It's in Memory Training Algorithms.
Reactions: E-Curbi2
Not New to Overclock.net
I am not interested in your ns. I am interested in your screen "3 min stable".
If you declare that your 11900k for 4800 memory needs
sa 0.85 with vccio2 1.05 4800c17 then you must confirm it with a more serious test - for example LinX full memory or Gsat.
Just the same I'm interested in overclocking the memory and the screen from 3 min test does not give any benefit, no conclusions can be drawn from it.
You write what you want to go higher (5066), but how can you go higher if you do not know how much "really" you need sa io on the previous step (4800)?
This is strange to read from the old-timer of the forum. Most newbies learn from the screenshots of other more experienced overclockers. Please do not post screenshots of 3 minutes of tests.
You are misleading beginners, and you spoil the opinion of yourself.
stop dude. you are literally embarrassing yourself. you have no clue anything about ram oc and what each tool signifies.
if i post now hci on that sa/io. will you just refrain from posting more silly comments?? nope. you will still behave like you know everything when you never test anything.
ignorant
ppl and their assumptions is what limit their growth.
SP95 Prilimary test: 1.33V bios set LLC6, 5.1 GHz all core, and 4.5 GHz ring, 10 min R23, AVX512 off.
Edit: min 5.1 GHz R23 volt is 1.32V bios set LLC6.
Edit2: 5.2 GHz R23 volt 1.44V bios set LLC6
2489910
2489911
Single Dimm 1:1 4133... two dimms is still a no go:ROFLMAO:
2489914
What kinda volts are you running? Also, what can you do with 2 dimms?
Only used VDIMM=1.7, others left AUTO. Still benching with 2 dimms. CPU 1.34 llc6 5.1&4.5
2489917
Reactions: YoungChris
