3441 - 3460 of 3860 Posts
One more step...DR 4000 MHz 16-18 gear 1 :ROFLMAO:
2514497
Reactions: PhoenixMDA
Does anyone still use Taiphoon burner to verify their memory modules being b-die etc? Malwarebytes browser guard blocks the website as a Trojan. Are there alternatives?
Discussion Starter · #3,445 ·
You know it's b-die if you can run 4000+ with sub 300 TRFC and sub c16 ;)
Reactions: YoungChris
Damn, that's nice!
Retail chip? Full ambient? Voltages? XMP timings working for daily? Can 1t boot, even if not fully stable?
Thanks mate!
XMP doesn't work...tRCD has to be 18 to run over 3 cycles. CPU is AIO cooled and ram is an 8 cm fan cooled.
I can only boot 1t up to 3733, but haven't tried higher volts for 3866 1t yet.
For 4000 atm I need io1=1.4V mcio=1.6V sa=1.65V:confused:
Edit: boxed retail chip
Well I remember using Taiphoon burner some time ago on my Corsair Dominator 3466 32GB kit and I'm fairly certain it reported Samsung b-die. However I can not run this kit higher than 3800Mhz.
Which modules exactly you need to confirm?
My kit is a bit of an oddball Corsair Dominator platinum RGB kit. It's a 32GB x 4 3466Mhz kit which is not easily found on Corsair's product pages.
Discussion Starter · #3,453 ·
So what does the kit say on the sticker?
i have a question what heatsinks are compatible with a2 pcb dr sticks. i have bartxstore samsung bdie a2 heatsink unfortunately the nut is a bit too tall which leads to the copper bending inward and the memory chip on the side do not contact. tldr its a **** show.
