1 - 17 of 17 Posts
Hey Ya'll!
I am about to overclock my XFX 6800GS. I was wondering what are some save speeds without pushing it to far! Stock its 485/1100. My 3dMark05 scorer is 5657. I sort of want to break the 6K hehe. Do you guys think that is possible? Also 5657 is that a little to low for me 6800GS?
Originally Posted by RaCeR123
Hey Ya'll!
Just keep upping the speed until it begins to artifact. ATI Tool 0.25 can do the o/c for you and stress test at the same time. Very unlikely you could damage a card by sensible overclocking as they will thermal throttle if too hot.
Thanks I will try that in a minute. Also I heard that the best performance drivers are the Xg drivers anyone know where to get that? Or whats the best one out there? Also how much image quality would I lose? thanks
Discussion Starter #4
K i just installed ATI Tool. and i am wondering what to do hehe. I have 6 sliders split into 3 categories. I know somewhat what to do but i Just want to make sure. Also it says that my memory is 550. but I have 1100. do I just X2 ? And which slider should i move the last 2 ones? or select link a sliders together. And then after I am done with settings my speeds click on search for artifacts?
Yep, memory is DDR so x2 for effective speed.
Just click find max core and max memory and let each test run artifact free for between 30 and 60 mins, then you're good to game
Discussion Starter #6
I just ran the Artifacting test and i shut it down after about 45 minutes. well when i stopped it my windows looked all messed up and i had to restart in order to get it to work again. now I am back at default speed. any know what the problem might be?
It probably just ran a bit too high. If you manually set the 3D clocks to just below when the problem occured hopefully that will sort it out.
Discussion Starter #8
k i just ran 3dmark05 and broke the 6k
i am gonna lower it a little tho because the card is getting a little bit hot.
Hi guys i'm kinda new in this forum but nwyz i have the same video card and i would like to OC it and i guess my question is how should i do it.
I have no idea to how to do it and plus i just build a new pc because i got tired of the old hp pc that i had.
let me know thanks
let me know thanks
Just follow the posts above, all the info you need is there.
okey i found the program can you guys tell me what the limit of overcling this card without burning it
i'm using ati tool also wich one should i scroll there six of them
Just use the "Find Max Core" and "Find Max Mem" buttons in ATi Tool.
okey now dd that and my computer its kinda screw up so i need to lower down the ati tool or somthing right?
but i cant even get into windows
please help
Get the XG drivers at www.tweaksrus.com in the downloads section. They should have the latest modified version.
EDIT//// Ooops, just saw the date on that post, probably a little late....lol.
1 - 17 of 17 Posts
