1 - 4 of 4 Posts
Hello everyone first post hope in right place. I need help in understanding if im doing anything wrong. After much research I cant work out if my motherboard has reached its limit or if something else is wrong which im not seeing.
my stock system:
200FSB 2.2 NB and 2.4HT
8350 4ghz (stock volt)
2133mhz 2 x 4gb ram (stock volt)
7950 3GB GPU
noctua 14 AIR idle 23C load 40C
gigabyte 970a-ud3 rev1.2 with LLC EXTREME - F7 latest BIOS
coolermaster enforcer case with 650w PSU - 2x200mm and 4x120mm fans
C1E, C6, C'N'Q, APM, Turbo - disabled
current OC state:
4.4ghz (stock volt 1.3875V)
2.2NB and 2.2HT (HT lowered to match)
2133mhz RAM - NO HARD FAULTS OR PRIME ERRORS for hours
my issue is this... when I try overclock now I have to start increasing volts but I cant seem to get stable 4.7GHZ. The below test is PRIME cycling through steps not necessarily running for hours but at least this way I know if it even wrks in the slightest before I leave it for a while.
these are what I need to do in order for prime not to spit out errors or crash (again five minute tests will do longer when I know what works)
TEMPS never pass 60C during the below tests.
FSB 200 DEFAULT
VOLT 1.4125 in BIOS - CPUZ MAX 1.444V under PRIME
4.4GHZ no whine or VDROP
4.5GHZ every minute or so volt drops to 1.17V with slight whine from MOBO for approx. 5secs)
4.6GHZ STRAIGHT CRASH on PRIME
VOLT 1.4375 in BIOS - CPUZ MAX 1.470V under PRIME
4.5GHZ every minute or so volt drops to 1.2V with slight whine from MOBO for approx. 5secs)
4.6GHZ every minute or so volt drops to 1.2V with slight whine from MOBO for approx. 5secs)
4.7GHZ STRAIGHT CRASH on PRIME
VOLT 1.4625 in BIOS - CPUZ MAX 1.5V under PRIME
4.6GHZ every minute or so volt drops to 1.23V with slight whine from MOBO for approx. 5secs)
FSB INCREASED FROM 200 to 230
VOLT 1.4625 in BIOS - CPUZ MAX 1.488V under PRIME
4.6GHZ no whine or VDROP
VOLT 1.4875 in BIOS - CPUZ MAX 1.520V under PRIME
4.7GHZ no whine or VDROP
4.8GHZ STRAIGHT CRASH on PRIME
FSB INCREASED FROM 230 to 240 (MOTHERBOARD WILL NOT POST ABOVE 240 even with stock and MOBO range says 200-500)
have I done anything bad or am I just restricted to the most stable 4.6GHZ at 1.488V. why is there whining when 200fsb but not 230?
can you give us a screen from occt with vcore and core temps ???
what temperature is measured? Here is an example of thermal throttle and vdrop in third core
1 - 4 of 4 Posts
