1 - 6 of 6 Posts
Could be a laundry list of things. But if your stable when everything is at stock, then chances are either ur vcore is too low or ur nb is overclocked like crazy and u dont have enough juice to it. But from experience, I would say the former is the cause. Can you post a screenie of cpuz and temps?
bsod while stress testing is usually correlated with ram instability. as you raise your fsb, your ram is also oc'ed. try dropping ram speed a notch or loosening timing.
if your v-core is too low, pc will simply reboot while priming. bsod=ram instability
what are your settings?
Discussion Starter · #6 ·
Here is the error I'm getting.
STOP Error 0x00000124: WHEA_UNCORRECTABLE_ERROR
STOP error 0x124 means that a fatal hardware error has occurred. uses the error data that is provided by the Windows Hardware Error Architecture (WHEA). STOP code 0x00000124 may also display "WHEA_UNCORRECTABLE_ERROR" on the same STOP message.
1 - 6 of 6 Posts
