1 - 11 of 11 Posts
Hello everyone,
I have a dell
I want to overclock my intel pentium 4 3 ghz
My bios are locked so I need to use software. I don't know what motherboard I have in everest all it says is
Motherboard Properties:
Motherboard ID <DMI>
Motherboard Name Dell Dimension 8300
Front Side Bus Properties:
Bus Type Intel NetBurst
Bus Width 64-bit
Real Clock 200 MHz (QDR)
Effective Clock 800 MHz
Bandwidth 6400 MB/s
Memory Bus Properties:
Bus Type Dual DDR SDRAM
Bus Width 128-bit
Real Clock 200 MHz (DDR)
Effective Clock 400 MHz
Bandwidth 6400 MB/s
Chipset Bus Properties:
Bus Type Intel Hub Interface
Bus Width 8-bit
Real Clock 67 MHz (QDR)
Effective Clock 267 MHz
Bandwidth 267 MB/s
Motherboard Manufacturer:
Company Name Dell Computer Corporation
Product Information http://www.dell.com
BIOS Download http://support.dell.com
Here is my CPU
CPU Properties:
CPU Type Intel Pentium 4, 3000 MHz (15 x 200)
CPU Alias Northwood HyperThreading
CPU Stepping D1
Instruction Set x86, MMX, SSE, SSE2
Original Clock 3000 MHz
Min / Max CPU Multiplier 15x / 15x
Engineering Sample No
L1 Trace Cache 12K Instructions
L1 Data Cache 8 KB
L2 Cache 512 KB (On-Die, ECC, ATC, Full-Speed)
Multi CPU:
Motherboard ID DELL Dim 8300
CPU #0 Intel(R) Pentium(R) 4 CPU 3.00GHz, 2992 MHz
CPU #1 Intel(R) Pentium(R) 4 CPU 3.00GHz, 2992 MHz
CPU Physical Info:
Package Type 478 Pin uPGA
Package Size 3.50 cm x 3.50 cm
Transistors 55 million
Process Technology 6M, 0.13 um, CMOS, Cu, Low-K
Die Size 131 mm2
Core Voltage 1.475 - 1.55 V
I/O Voltage 1.475 - 1.55 V
Typical Power 38.7 - 89.0 W (depending on clock speed)
Maximum Power 49 - 109 W (depending on clock speed)
CPU Manufacturer:
Company Name Intel Corporation
Product Information http://www.intel.com/products/browse/processor.htm
CPU Utilization:
CPU #1 / HTT Unit #1 0 %
CPU #1 / HTT Unit #2 3 %
Thank You,
Robert
there is no point in overclocking a dell. because they lock the settings
try software overclocking but i tried and it put the cpu right back to the stock...
so for christmas i just swapped everything.
What software did you use?
Your gonna have to crack the case open and take a look around. Look for Letters numbers or both, also youll need to figure out what your clock generator is, its the chip next to the little silver crystal that has a number starting with 14.*** chip will prably have ICS or CY stamped on it then some numbers like 950240(give or take a couple). Its gonna take some time to figure everything out, download a software program to overclock and then set it up. My suggestion would be to just go out and buy a retail board that works with your system, can find some pretty good overclockers for under $100.
Welcome to the forums.
If you go with a new mobo, be cautioned that some Dell systems use proprietary PSUs that will not work with "normal" motherboards. The stock PSU probably won't support a very good PSU, so it would be a worthwhile upgrade.
Dell PSU are all NON STANDERED.
So basicly, if you use a new mobo and dell PSU, you fry the motherboard and vice versa.
Problem is, is the fact the case is probobly Micro ATX, so a good motherboard is hard to find.
Can you tell us your budget? or what you want to do with teh computer?
1 - 11 of 11 Posts
