ok so i have read the overclocking amd guide and i have a few questions because my comp isnt handling it too well
let me tell you what i did
i lowered my multi to 5
and raised my fbs to eventually 260 without reboots in intervals of 15
so i go to run prime 95 and it says error with out even a minute of testing
so i lower the fbs to 250 and i run prime for 30 min and then my sys reboots
i have a few questions... when in the guide it says raise your ram settings
do i raise it to as high as they can go ?? or what should i stay around with pc3200 geil
What does it mean to have a 2:3 ratio for the memory .. as in ratio which numbers
i think that ram was my only problem ...but how much lower should my fbs be from when it can boot to when it can run stable ?
last thing is what should my volt be ...its on 1.6 Ccan i safely bring it to 1.7?
