1.252v underload 5.3/4.3 passed. I tried lower 10mv and r23 shows error message. I guess my sample is quite good but not the godlike type. I’m keen to keep this cpu. The temp is so much better than my SP87 12900k.
hmm... Looks like you are still throttling a little bit somewhere, that CB R23 score is pretty low for 5.3/4.3. Here is my SP 94 (P 103 / E 77) 12900KS, 5.3/4.3, loaded MB defaults, only set llc at -50% droop (EVGA), and static clocks at 5.3/4.3. (Default cache/ring, memory on defaults); full fat Windows 11 Pro, normal priority.
1.230v v-core under load, 360mm AIO
If we go by the “KS P score + 10 points = K/KF” rule, I am at 113 p core, and ran a full 20mv lower than your 112 CPU. I think that in all reality a +15/20 to the P score is a little more accurate. Not trying to discourage you here. You won the lottery, 100% hands down; but I think the days for $1000+ K/KF CPU’s are pretty much over, especially if they don’t have AVX512 support.
I’d keep that CPU, radically improve your cooling system, and win.
