This was in another thread on the Asus Maximus Z690 which should use the same LLC settings. You should adjust IA DC loadline according to these values for correct power and VID readings:
www.overclock.net
IA AC Loadline on the other hand will affect load voltages so you shouldn't change it from its current setting unless you want to actually change your voltages. However it only has an effect with Adaptive/Auto voltages.LLC1: 1.75 milliohms
LLC2: 1.46 milliohms
LLC3: 1.1 milliohms
LLC4: 0.98 milliohms
LLC5: 0.73 milliohms
LLC6: 0.49 milliohms
LLC7: 0.24 milliohms
LLC8: 0.01 milliohms (flat).
ASUS MAXIMUS Z690 EXTREME & i9-12900K GUIDE - Load...
Disclaimer ! These settings and methods are outside Intel's specifications, just like any other overclocking method. ---------------------------------------------------- Introduction: In a world increasingly concerned with natural resources, the watchword is efficiency. So, it's time to...
