1 - 10 of 10 Posts
first question is this, have you run a memory test program on your ram? and if i remember well u can do a 2-3-3-7 on that ram but allow me to check better. Do u have any cooling on that ram?
well...if u r thinking about ur vdimm then i dont think u should unless u have adequate cooling since the volts for that ram is meant only about 2.8..but u can try though but something is wrong here...ur system boots and runs fine enough right? whats ur voltage like for the cpu?
ok....thats sounds just about right but i just remembered something having seen ur attachment earlier... reduce ur bank cycle time and ur dram idle timer lower and try again...that should work...
i think that u should set ur trcd and ur trc lower. if i remember well those are the same things as what i said earlier. but check it out in the bios. coz ur bios definitions would state what they stand for
1 - 10 of 10 Posts
