1 - 20 of 29 Posts
Originally Posted by uck View Post
and the steps are:set up the core and memory clocks --> hit the test function in evga precision --> hit apply --> restart PC --> ati tool scan for artifacts.
CORECT me if i'm wrong!!
Don't bother with the memory.
Up the Shader and Core clocks -> Apply -> Use test / Ati-Tool artifact scan
->If stable then higher clocks
else lower clocks / up voltage
end if
anyone??
bump thread once per 24hrs please.
end if
Why not up the memory? The memory chips on these cards will easily go to 1000Mhz without a hitch.
If you are referring to getting the GPU/Shaders stable first, THEN upping the memory, then yes, fair point.
The memory generally doesn't show significant gains because memory isn't the bottleneck most of the time.
Get the core and shaders up and you'll see real improvement.
Yeah, most cards can break 700 core. Mine can't. Mine fails at OC'ing
You can always try but be careful of those temps. Its the load temps you gotta watch. Also, fan speed is adjustable and usually not defaulted anywhere near 100%, so if you do OC just up your fan speed too and you should be ok. Alot of the factory overclocked geforce cards use stock coolers so most stock coolers can handle at least a slight oc. Its always worth a try.
Ok, with fan speed at 100%, doing FurMark at 1440x900 resolution, it went from 53-82.
From 82 it just hovered between 81-82.
It is safe to go and overclock?
If so, my core clock is 600MHz, and my shaders 1500MHz.
What should I overclock them to?
Thanks.
Go up slow, try 20Mhz at a time for core, 50 for shader.
EDIT: But saying that 82c seems pretty high for stock settings, I wouldn't feel comfortable overclocking with the stock cooler.
May have something to do with your 'Random generic' case, I assume it has poor cooling
I like computers
I would recommend using the latest Rivatuner to adjust GPU clocks and fan speed settings, and ATI Tool to test stability (artifact scanning). Each card will OC differently though. My Rev. 1 8800GT does 700/1800/1000 no sweat, my second one (unknow rev. #) can only do 675/1700/1000 and it has a better cooler and maxes out at 55 C? Where my Rev. 1 hits 80 C?
1 - 20 of 29 Posts
