It might seem slow,
you lowered you HT and your ram with out increasing your CPU Frequency (FSB).
Try using a lower Multi and raising your Cpu Frequency (FSB) and it should seem faster again.
For your HT, you want to keep it close to 1000 or a little above.
When you raise your CPU frequency you raise your ram speed and your HT
Just start off small, and work for a larger over clock ( and test stability after each change).
Here's a link to guide... It should Help you out
http://www.overclock.net/amd-general...ocket-am2.html
