1. You should get it pretty far. I don't know your temps but with stock you could probably get 2.7GHz.
2. Tell us your temperatures.
3. It's better to overclock with BIOS than software.
4. The reason it's not detecting your CPU is because you might not have the required motherboard chipset.
5. Tell us the voltage of the CPU as well as the multiplier.
