Overclocking booting problem
822 Views 19 Replies 6 Participants Last post by  Cyberbot
Hello all,
I have been overclocking my E8400 and can't get my computer to boot once I put the FSB to 412 or above (3708MHz clock speed). Instead of a POST, a screen simply appears saying 'please insert boot device'.
My CPU temperature is not very high when I run Prime 95 with the FSB at 411. However one of the workers does stop working soon after I begin running the torture test, so I'm assuming that this overclock is not perfectly stable. Increasing the voltage might help but I don't know how to alter this as the options in the P5KPL-CM's BIOS are badly labeled. Does anyone know which options control which components?
The main problem is still the fact that it doesn't boot however.
I can't find another thread with this topic anywhere.
Any help would be appreciated
1 - 20 of 20 Posts
Can you post what settings are in the bios?
yeah here is what I know:
C1E Support- disabled
EIST- disabled
legacy disk support- disabled
Thats it? Im sure there are more settings you can change.
Originally Posted by mr soriyama View Post
..can't get my computer to boot once I put the FSB to 412 or above (3708MHz clock speed). Instead of a POST, a screen simply appears saying 'please insert boot device'.
Increase the FSB a little more and you'll be reflashing the BIOS, a little more still and you'll be reformatting and reinstalling the OS.
What settings are you changing to overclock? Just FSB?
And, just out of curiosity, have you read a whole bunch of overclocking guides and stickies?
How would that reflash the BIOS? I don't understand. I am changing the FSB but also the memory divider option and the memory timings so that the memory doesn't interfere with the overclock. Also I've disabled the EIST. And yes I have read some guides.
I think they're asking settings like BLCK, Core Voltage, QPI and sheet like that.
OK here are the settings:
Legacy Diskette A- Disabled
SATA1 Hard Disk ST3500320AS:
LBA/Large Mode- Auto
Block (Multi-Sector Transfer) M- Auto
PIO Mode- Auto
DMA Mode- Auto
SMART Monitoring- Auto
32Bit Data Transfer- Enabled
SATA3 Asus DRW-2014L1T:
PIO Mode- Auto
DMA Mode- Auto
IDE Configuration:
ATA/IDE Configuration- Enhanced
Enhanced Mode Support On- S-ATA
IDE Detect Time Out (Sec)- 35
AMIBIOS:
Version: 0305
JumperFree Configuration:
AI Overclocking- Manual
CPU Frequency- 411
DRAM Frequency- 667 MHz
1.8V Dual Over Voltage- Auto
1.5V Over Voltage- Auto
VTT_CPU Over Voltage-Auto
1.25V Over Voltage- Auto
CPU Configuration:
CPU Ratio Setting- 9.0
C1E Support- Disabled
Max CPUID Value Limit- Disabled
Vanderpool Technology- Enabled
CPU TM Function- Enabled
Execute Disable Bit- Enabled
North Bridge Chipset Configuration:
Memory Remap Feature- Enabled
Configure DRAM Timing by SPD- Disabled
CAS# Latency- 6
RAS# to CAS# Delay- 6
RAS# Precharge- 6
RAS# Activate to Precharge- 15
Initiate Graphic Adapter- PEG/PCI
Internal Graphics Mode Select- Enabled, 8MB
PEG Port Configuration:
PEG Force x1- Disabled
South Bridge Chipset Configuration:
Audio Controller- Azalia
Front Panel Support Type- HD Audio
Onboard Devices Configuration:
Onboard PCIE GbE LAN- Enabled
LAN Option ROM- Disabled
Serial Port 1 Address- 3F8/IRQ4
Parallel Port Address- 378
Parallel Port Mode- ECP
ECP Mode DMA Channel- DMA3
Parallel Port IRQ- IRQ7
PCI/PnP Settings:
Plug And Play O/S- No
PCI Latency Timer- 64
Allocate IRQ to PCI VGA- Yes
Palette Snooping- Disabled
IRQ3,4,5,7,9,10,11,14,15 assigned to- PCI Device
Power:
Suspend Mode- Auto
ACPI 2.0 Support- Disabled
ACPI APIC support- Enabled
Hardware Monitor:
CPU Q-Fan Control- Disabled
Boot Device Priority:
1st Boot Device- Removable Dev.
2nd Boot Device- HDD: 3M-ST3500320AS
3rd Boot Device- CDROM:4M-Asus DRW-
Boot Settings Configuration:
Quick Boot- Enabled
AddOn ROM Display Mode- Force BIOS
Bootup Num-Lock- On
PS/2 Mouse Support- Disabled
Interrupt 19 Capture- Disabled
When you start getting to non-bootable overclocks, if you push farther, (or just happen to jump to far) BIOS corruption will result. then the BIOS has to be reflashed. If you push the memory to far, it will start writing bad data to the HDD, and the OS becomes corrupted.
And don't bother posting all that junk. Screen shots of CPU-Z's CPU, Memory and SPD tabs will be all that is needed...and will provide a lot more useful info.
bump
....LOL
bump
Thanks, I will post screenshots soon.
bump
Reset all the settings and go find some tutorial on how to properly overclock. I admit that I do not know much about overclocking, but it seems like you have pushed your PC too far.
1 - 20 of 20 Posts
