Hi!
I couldn't find a thread for small questions so I decided to create a new one.
My question is, does more voltage always add more stability as long as the voltage is in reasonable range and temperatures are in check?
What I mean is, would it make sense to crank up all the voltages to their highest values I'm comfortable with, and then find the highest stable clocks. And after that to find the lowest voltages those clocks are stable on. I'd figure this approach would speed up the oc process quite a bit.
