i can get 3Ghz stable at 1.38 but 3.2 needs 1.44 and 3.3 is just unstable no matter the voltages and in the similar way you described,so it might be same with you.try finding your fsb wall by dropping down the multi to 6.
Originally Posted by Miko2323 ![]() Stuck at 2.9 Myself. 360 FSB. Any workaround? And pumping more than 4.7 volts through it gona make a diference??? |
