I got coolbits and tried to overclock my Nvidia FX5600. I also noticed in another Threadand this guy had a 5600 also and his stock clocks were a lot higher than mine (core-234mhz, mem-399mhz).
Anyways to my problem, if I adjust the speeds higher or lower, the performance of the card falls on its face. Here are some FPS tests I did with 3dmark2001
Test------Stock Card------MemOnly+22mhz------CoreOnly+31mhz
Game1Low 71.9fps------------26.2fps---------------25.8fps
Game1High 35.5fps------------16.5fps---------------16.3fps
Game3High 44.8fps------------15.9fps---------------15.0fps
HighResTest22.0fps-------------7.2fps----------------6.9fps
I then took off like 20mhz on the core and it had similar readings the core +
Is there something limiting my actions? Thank you for the help
