1 - 6 of 6 Posts
Hello,
I'm relatively a newb here but I just built my first computer and I put in the aforementioned graphics card. Once I booted up the system and installed the necessary things I wanted on it, I started up the game I like to play, Everquest II. I cranked up the graphics to max and it ran like a dream. Unfortunately, about 3 days later EQII began to run very sluggish. For those of you unfamiliar with that concept, what I mean by that is when I tried to turn it ran almost frame by frame. So, my problems are these: I have no idea why it started running sluggish and I also have no idea about how to go about overclocking things. I want to overclock the video card, the ram and the processor. If anyone can help me with this, I'd really appreciate this.
Thank you in advance!
probably just your display driver got corrupted then, uninstall it and run driver cleaner 3, then reinstall the driver, should fix it. its also worth doing the basic things like disk defragging and running diagnostic tools to fix any problems.
1 - 6 of 6 Posts
