1 - 8 of 8 Posts
Ok like this isn't asking for ocing help, cause I know how to OC lol. But I am using my ASUS M4A785TD-V EVO with onboard 4200 till I can RMA my 4890, so I cant use Formula IV for a while.
AOD is a fail for me, I am done using it. I have over volted through it and got a stable 4.0ghz.
my question is. What OC software would be good to over volt my CPU since I cant do it from the board. Should I use like ASUS Turbo V? or something like that. Since the board is made to work with Turbo V
1689 Federalist
So what are you saying you normally Oc with the buttons on the crosshair?
Sent from my ERIS using Tapatalk
Originally Posted by GanjaSMK View Post
You shouldn't use software to overclock, you should use your BIOS.
What did I just say. I cant Overvolt from the Bios on this board.
I am using a different board till I RMA my ATi 4890
I'm confused. How are you unable to over volt your voltages via BIOS? Especially on the CH IV?
EDIT: Pardon my quick skim - I didn't realize you were on another board until just now. I'd say AOD is probably your best bet - but since you're not too keen on it try Easy Tune (I have no idea what Easy Tune does but I know others have used it for software overclocking).
I am using Asus turbo V right now since the board has a Turbo V chip in it, to work with Turbo V. Its coming along ok. trying to beat my 4.0ghz record
1 - 8 of 8 Posts
