I'd like to help, but unfortunately this is all I'm able to offer. But let's get the ball rolling!
What you're seeing is a combination of vdrop and vdroop. Vdrop is first because that's when the voltage is lower than what you set it to in the BIOS. But vdroop is when the voltage droops under load. So, when it's idling, the voltage is a little bit higher.
If you have Load Line Calibration, or LLC, then turn that on. However, this may or may not make the voltage spike. But in most cases, it can help with vdroop. So, experiment with it and see what your results are.
As for setting the voltage in BIOS to 1.5v: believe it or not, that's safe. The actual voltage running through the chip is 1.432v at full load, and it's safe for long-term use as long as your temps aren't getting too high at full load. I say that with this voltage being as high as it is, try to keep the full load under 70 to 75°C, and everything should be 100% safe for long-term usage.
Also, if you want a better GUI but the same stress test, then give Orthos a try. It's Prime95 with a different GUI and it lacks all of the features that have nothing to do with overclockers. Plus, it's much more obvious when it fails (especially from a distance).
That's as much as I know right now. I hope that this is a good start.
