1 - 9 of 9 Posts
ok total noob to this read some stickies and stuff here but just really not well up on it<br />
<br />
ok so ive overclocked my Pentium D 2.8ghz DUAL CORE to 3.06ghz (10%) but after that my SATA hd gets errors after that so gave up but when i remove the sata and overclock it by 30% computer wont even post <br />
<br />
anyone help me overclock it properly <br />
<br />
ASUS P5VDC-X
<tr>
<div>
Originally Posted by <strong>ando2k6</strong>
<a href="showthread.php?s=fb118d83aa0ea05832d812d721028acf&p=1384667#post1384667" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">ok total noob to this read some stickies and stuff here but just really not well up on it<br />
<br />
<br />
<br />
ASUS P5VDC-X</div>
</td>
</tr>
</table>
</div>Hello, I believe this will be down to the motherboard not having a PCI Lock and therefore the SATA ports are not locked either.<br />
<br />
Look in your BIOS menu to see if you can lock this function before trying to overclock any more <img src="/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" />
cant see it in my bios<br />
<br />
posted over at another forum guy suggested on getting another board he reccommened P5LD2 Deluxe or some other asus cant remember it <br />
<br />
so if i try and overclcok again without the PCI LOCK feature will definatly mess the hd up again?<br />
<br />
and is that board ok or can you reccomend a better/cheaper one lol<br />
<br />
BOOH well that mobo only supports ddr2 so if i want one gotta get new ram aswell talking near £200
Welcome to the forum! You should consider filling in your system spec by clicking on the User CP link above. This would help us a lot more in helping you overclock the system. Locking your PCI and AGP freq will help a bunch in squeezing more out of the CPU. If you can somehow get screenshots of your bios screens, I can help you out with overclocking it.
Discussion Starter #5
ok thnx for that done what you asked ill try and get bios screens soon recovering a partition atm<br />
<br />
bahh cant get it to go on the bottom of my post like yours looked the cp cant find the option<br />
<br />
Aanyway<br />
<br />
MOTHERBOARD ASUS P5VDC-X (latest bios)<br />
CPU Pentium D 2.80GHZ DUAL CORE<br />
RAM 2x 512mb Hynix Matched Sticks DDR PC3200<br />
HD Samsung Spinpoint 160Gb SATA<br />
GRAPHICS MSI NVIDIA FX5200<br />
PSU 550WATT QTEC
Below are a couple snapshots of my bios.<br />
<img src="http://i2.photobucket.com/albums/y19/gohandbz8/IMG_0995.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br />
<img src="http://i2.photobucket.com/albums/y19/gohandbz8/IMG_0994.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br />
<br />
On the first screen if you have the options available to you, change MPS revision to 1.4 and disable spread spectrum. for the "configure Dram timing by SPD," I would just keep that on enabled so you can tweak later on. <br />
<br />
On the 2nd screenshot, hopefully you will have the "AGP/PCI Frequency." This is where you lock it in. 66/33Mhz is what you should set it to. Hope this can help you.
Discussion Starter #7
ok heres some images not v good quality took with 1mp cam has more or less the same options as your accept for altering the voltage <br />
<br />
i altered the agp/pci myself was originally set to auto and overclocking was set to auto 10%<br />
<br />
so what should i do<br />
<br />
thanks for this<br />
<br />
<br />
<img src="http://mediaman.b4site.com/15000001.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br />
<br />
<img src="http://mediaman.b4site.com/15000002.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br />
<br />
<img src="http://mediaman.b4site.com/15000003.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br />
<br />
ok well i had a fiddle set my ram to 266mhz and a ultra setting but now my ram is low :S<br />
<br />
got a extra 300mhz out of em<br />
clocks from clockgen any more help<br />
<br />
<img src="http://mediaman.b4site.com/Image1.png" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br />
<br />
had another update again few tweaks changed the channel options to dual instead of single upped the cpu again looking nice but definatly think i need some better ram just aint fast enough <br />
im still thinking thats pretty good getting a extra 670mhz out of the cpu pretty nice seems pretty stable gonna try alter the ram frequencies little trial and error i suppose<br />
<br />
<br />
clockgen update<br />
<br />
<img src="http://mediaman.b4site.com/Image2.png" border="0" alt="" onload="NcodeImageResizer.createOn(this);" />
Looking good!!! Since you can't adjust your voltage, monitor your vcore closely with pc probe. The motherboard will up the vcore accordingly. Also, keep checking your temperature and run prime 95 to make sure you are stable. Looks like you got the hang of it. Good Luck!
Discussion Starter #9
well after some BSODS pc wouldnt boot to windows had to format and re install had to set it back to factory to install kept getting BSODS in setup<br><br>
UNPAGED AREA IN PAGED AREA<br><br>
BAD POOL HEADER<br><br>
so now at 3.30ghz the ram clock is still very low though need some more advice on what to do next
1 - 9 of 9 Posts
