Hi, I want to OC my CPU more but in order for me to do this I have to up the voltage on the CPU. At stock, the CPU ran 1.79GHz/1.4 voltage. Right now I have it at 2.66GHz/1.675 voltage. This is the max oc'ing I can do with this voltage for it to be stable. The problem is that when I hit 2.7GHz/1.7 voltage for CPU, then the computer shuts down after about 5 min of usage. It's not over heating because I have liquid cooling but I can't find out why this is happening. Then when I up the voltage to a 1.725 at 2.7 Ghz, the computer just freezes. What should I do in order to reach a higher CPU speed?
