1 - 6 of 6 Posts
Hi guys im new here and new to overclocking...
I Just bought my new computer (last fried up
) and i want to know how can i get my memory to 533(1066) MHz cause i bought it for that and CPU-Z says that its working on 400(800) MHz
You can see my pc setting on signature, tnx
You have two options:
1. If your motherboard gives you the option you could simply change up the memory multiplier. That will simply let it run at a higher frequency, potentially up to 533/1066.
2. The other option would be to bump up your FSB which in turn will make your memory run faster. It may take a combination of FSB and memory multiplier tweaks to get your memory to that speed but it should be possible.
FSB was 200MHz on last try, i raised it to 400MHz and my computer couldnt boot, i got into boot after CMOS reset and "loaded" my last preset with 2.18v and 1067MHz option in memory clock
1 - 6 of 6 Posts
