I was going to re-overclock my system now that I have the temperatures straightened out a bit better and everyone says to begin raising the multiplier until it won't run on stock voltage anymore - which is fine but:
I fail to find anywhere where the stock voltage of the i7 2600k is listed. It fluctuates between certain values etc.....
and if you leave it on "auto" and raise multiplier , the motherboard will and wouldautomatically raise the voltage to be necessary to meet the newly input multiplier.
so I must be blind but is there a stock value people use instead of "auto" and continue to raise the multiplier based on that voltage? I think I heard some say it was 1.200? and not to exceed 1.350?
