1 - 6 of 6 Posts
Hi ppl need help in overclocking my i7 950
my config is:
i7 950
Cooler Master N620 Cpu cooler
Asus P6X58D-E
Corsiar dominator 3X2GB DDR3 PC3-12800(1600MHz) CMP6GX3M3A1600C8
Corsiar TX750 psu
WD Green 1TB
i want an decent overclock abt 3.8 with HT enabled, plz help i am new to overclocking n noob in all these
voltage n multiplier tweaking
Set voltage to about 1.33, multiplier to 21 and clock to ~180
180MHz * 21 = 3800MHz
Stress test it, intel burn test is a good one, SuperPi.
For 6 hours or so, if it BSOD's, turn the voltage up a little tiny bit at a time.
That's pretty much all there is to it. From there it's working to getting a lower voltage to your stable OC.
thanks guys but need more detailed settings coz doing this for the first time
i am OverClocking for the first so a bit more concerned
i want an decent 3.8 or 3.6 clock with HT n turbo "on"
using plz help.
also my ram not runnning at 1600mhz what cud be wrng ?
using plz help.
You need to read some of the guides that are posted all over this forum, and then we can help you more.
1 - 6 of 6 Posts
