1 - 8 of 8 Posts
Please fill out your system specs under the "user cp" tab on the top left of the main page. We need this info to give you good information.
Also, check out the Intel overclocking guide that's linked in my signature. Assuming you have an overclockable motherboard, that will be a very useful resource for you.
Originally Posted by Fenser
Can You tell me now?
Taeric what You mean overclockable motherboard?
some motherboards have there BIOS settings locked, thus not allowing you to change settings to overclock anything..
take a look through this--->http://www.overclock.net/overclock.p...uide-intel.htm
Some motherboards have a variety of settings that permit stable overclocking. Many others lock out some or all of those features, greatly limiting (or eliminating) the ability to overclock.
The easiest way to tell which category your motherboard falls under is to reboot and go into the BIOS. If there are options for setting frequencies (CPU, RAM, PCI, AGP), voltages, and RAM timings, you're in good shape. I'm not familiar with your P4B, so I can't assess how overclockable your mobo is. My advice is to check out your BIOS and carefully read the Intel overclocking guide. Once you do so, feel free to post back with any questions you might have.
What meens this messages in Prime95
FATAL ERROR: Rounding was 0.5, expected less than 0.4
Hardware failure detected,consult stress.txt file.
Execution halted.
Choose Test/Continue to restart
That message means there is some form of instability in your system. Run Memtest86 to see if it's a RAM issue. If that software runs through a couple of tests with no errors, it's most likely a CPU issue.
1 - 8 of 8 Posts
