1 - 20 of 20 Posts
ok so I have overclocked my rig to 2.45 ghz right
Thats stable but my pci/whatever doesnt stay at a 2:1 ratio it is ex: 81/40 instead of 80/40 when its on 2.4
so I sit at 2.4
my fbs is at 490 I think and its 400 default
I cant seem to jump over to 2.5 what could I do (my voltages are 1.55 on cpu and 2.7 ram)
Actually, they do make a difference. A volt at 1.7 might get you over 2.5 but I don't know what ur temp situation is.
Reactions: Inquisitor
but wouldn't it fail regardless if the pci-agp freq's go over?
no, it doesn't have to fail. If the freq goes over then you can data corruption on you're HDD among other things. Or it could work perfectly, tho this doesn't happen very often.
well, that's teh first time i've heard that, i always thought you had to lock it, you can go over like 2 mhz each side and then it screws up.... but it does make sense about corruption though. it still doesen't make a difference whether or not it gets corrupted, he's not booting until he locks it at 66/33.
AGP / PCI lock... it is normally set to auto in your bios, set it to 66/33. you hdd aren't fried, either. it's corrupt data..re-format adn you're good to go
is that how it's spelled? pci clk?
Originally Posted by The Dark Inquisitor
I think I can get it to work
now whats the pci clk??
1 - 20 of 20 Posts
