1 - 13 of 13 Posts
Ok so i got a 2.8ghz northwood on on a Gigabyte 8KNXP motherboard (400mhz FSB)
2x512 Corsair XMS PC3200 Low Latency RAM
watercooled (cpu never goes over 44 C)
Now i overclocked to 3.149Ghz and then i ran into a snag. I upped the voltage to 1.535 and hten it became unstalbe. I upped the voltage twice (each incriment is .0125V) and still stability issues and then i went back to 1.535 and this time i upped the DIMM voltage +0.1V. Should i have done this or is this dangerous? Also... i cant find hte DIMM timings at all in my BIOS so i have no idea what my timings are... any suggestions? Thanks guys
2x512 Corsair XMS Low Latency RAM
well if you want to see the timings use cpu-z(link below)
http://www.majorgeeks.com/download425.html
but if ypu want to ajust them then keep on looking and what are the menu opions?
i dont know about the voltage but i think is shold help
ive looked through the menu multiple times and theres nothing about the RAM timings. Do you think the DIMM voltage upage will have any bad consequences in teh future?
well i know that uping the vcore will(evencly)screw your cpu i dont know about dimm's but my guess is yes
well i think it shold(if its there)be under somesort of "chipset" thing
<don't forget reps
Are the consequences just like the consequences of upping ur CPU voltage? As in will it just shorten hte life span? Or should i expect a lot of problems very quickly.
And my computer just restarted and the error i got was "Memory_Management" and it was the blue screen (XP) so im gonna reset back to good OC values after hte next crash.
Discussion Starter · #9 ·
I splurged on this computer so everything is top notch quality
The RAM is only pc3200 though... could that be the problem? I got it to PC435 or so and thats when things started giving out. I got a "memory_management" blue screen when it was unstable...
I've a gigabyte board too(different model but) and to access the dimm timings press ctrl-F1(in the biios screen) and it will bring an option called advanced settings from there you can change the timings.-at least you can on mine.
Discussion Starter · #12 ·
Why is the RAM ruled out? Couldnt it be that it exceeded its operating potential? My specs are...
Flashed-to-current Gigabyte 8KNXP on the 875 chipset (might be wrong on chipset)
2.8ghz P4 Northwood 800mhz HT enabled
asus V9950 (5950 chipset)
sound blaster audigy 2 zs pro
Enermax 475watt power supply ATX12V
2 raptors mirrored with 2x40mm fan and heatsinks each
watercooled CPU and GPU (north bridge is fan/hs)
Idle at 39C (according to MBM5) and full load at max 45C
1 - 13 of 13 Posts
