sorry man but i clicked on that screen shot and its tiny what are your temps?
also, what is your Vcore? (the volts to the cpu)
thanks for thatOriginally Posted by Archcry
Ye sorry, I noticed but I had to eat, better screenshot will be up in a minute or so.
Edit: This should do the trick!
Edit2: Added my rig to my signature
This will do.Originally Posted by looniam
thanks for that![]()
aside from one "warmer" core - which is no big deal- low 60s is great. 1.08 vcore (but check the bios, cpu-z doesn't always report correctly) is nice. keeping the voltage down along with a good heat-sink is very influential. but i think you can safely say your heat-sink is working.
hitting 4.4ghz with 1.2v (or less) @ 75c would be excellent! but that all depends on the chip, some will, some won't.
close.Originally Posted by Archcry
This will do.
I used to overclock my E8400 by bumping the Multiplier to the point the core speed reached the desired clock speed.
Then bump the voltage to make everything run stable.
To test this I let Prime95 run for around 12 hours, when it stayed stable I lowered the cpu voltage.
I was looping through this method for several days untill I encountered a problem while stress testing.
I decided to bump the voltage a to the last point it was stable on.
Does this method still apply to the new i5 processors?
~ Archcry
I think i'll leave it off for now.I see you have an MSI board; I know exactly what you're refering to. For overclocking, take them all off auto and put them to off/full power. The phase control allows the BIOS to decided whether your CPU is run in 1, 2, 3, 4 (or however many power phases your board has) in order to conserve power. However, this can cause instability when overclocking, so just turn all phase controls off. Generally speaking, more phases = smoother, cleaner power delivery. However, more phases means more power wasted through inefficiency (heating up the MOSFET's) as well, which is why MSI has auto phase control.
