1 - 20 of 42 Posts
Hi there guys..i kinda now a lil about Overclocking...i have Oc'ed my Athlon 3500+ Vince Core to 2.5 but was unstable in SP2004 and Super PI mod 1.5...but ran my games well.. the following settings were..<br />
__________________<br />
FSB : 250 |<br />
CPU Multi : x10 |-------\\ 2.5<br />
Mem Clock : DDR333 |-------/ Ghz<br />
HT : 4 |<br />
CPU Volt : 1.45 |<br />
__________________|<br />
<br />
I even had it to 2.6 but was unstable..and couldn't play anygames..and i also heard of ppl Overclocking the Vince core to 2.7 and 2.9 and would liek to help...pls drop a line..
i have my 3500+ sitting pretty at 2.7ghz with these settings<br />
FSB = 300<br />
Multi = 9<br />
HTT Multi 3x <br />
Ram on a 133 divider running at 200mhz<br />
1.5volts on the cpu<br />
1.7 volts on the chipset<br />
2.7 volts on the ram<br />
<br />
i am testing out the 300FSB being against my old overclock which was<br />
FSB 260<br />
Multi 10.5<br />
HTT Multi 4x<br />
Ram divider 166 which would run at 215 mhz<br />
1.5 volts on the cpu<br />
2.8 volts on the ram<br />
<br />
my chipset seems to get warm, i put a little fan on it. But it still gets warm I might pull it off today and replace the thermal material with as5 and see what happens. <br />
<br />
Good Luck
How do you change the divider on the ram?
<tr>
<div>
Originally Posted by <strong>burnstudios</strong>
<a href="showthread.php?s=d51c1a11b1f7d586c94ba64097780a71&p=1396503#post1396503" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">depends on your motherboard. look for memory settings or dram settings . then look for 400/266/133/100 ect those are your dividers.</div>
</td>
</tr>
</table>
</div>cheers, sorry to hijack post for a second there. rep+
Discussion Starter #8
Hi there guys..srry i have been busy... its almost 2 here...and im gettin tired..if some one is on in the morn to help me that would be kool...heres a pic of my settings @ running at 2.5 ohh..my Vcore can only goto 1.5 something..<br><br><a href="http://img80.imageshack.us/img80/496/occz4.jpg" target="_blank">http://img80.imageshack.us/img80/496/occz4.jpg</a><br><br>
here is my CPU-Z webpage too...<br><br><a href="http://valid.x86-secret.com/show_oc?id=129476" target="_blank">http://valid.x86-secret.com/show_oc?id=129476</a><br><br>
Im lookin to for a stable overclock a lil higher, maybe 2.6 maybe 2.7..<br>
i don't know much about ram timing, and my ram is poop anyways...with this overclock prime95 stops in like 2 seconds..but im abler t o game for hours..like normal..someone plss help...
ok, probably you will need to up your voltage a bit, try 1.5 volts .. also you can bring your HTT FREQ up a notch if your on 3xs you can bring it back up to 4. i seen your HTT was around 700mhz .. you want to keep it under 1080. and try 10.5 multi try 258 fsb x 10.5 which will give you 2.7ghz and try your ram at 166
Discussion Starter #11
<tr>
<div>
<a href="showthread.php?s=d51c1a11b1f7d586c94ba64097780a71&p=1399618#post1399618" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">ok, probably you will need to up your voltage a bit, try 1.5 volts .. also you can bring your HTT FREQ up a notch if your on 3xs you can bring it back up to 4. i seen your HTT was around 700mhz .. you want to keep it under 1080. and try 10.5 multi try 258 fsb x 10.5 which will give you 2.7ghz and try your ram at 166</div>
</td>
</tr>
</table>
</div>hi there i tried these settings..and wouldn't boot to windows..my ram goes to 200 to 600...its curently on 333mhz...was on 400mhz...anyone care to help
Depenadan on yout HSF you may need more vcore, keep the full load temp around 50c or below! <br />
Some things to consider...<br />
1. Your 420w PS may not be up to the task.<br />
2. Have you upped the mem controler voltage?<br />
3. Have you upped the RAMs voltage any and if we knew what RAM you had more could be said. Add it to your System Specs.<br />
4. In part #3 re: the FHS.
Discussion Starter #13
i just have poop ram...2 1 gigs sticks...and changes my ram timne frum auto to manual, and changed it from 400mhz to 333mhz, its just poop ram the voltage is set on auto...heres a pic<br />
of CPUZ again..<a href="http://valid.x86-secret.com/show_oc?id=129476" target="_blank">http://valid.x86-secret.com/show_oc?id=129476</a>
RAM that sucks will kill your overall overclock of your system. but if you want to see just wat your processor can do, then just drop your divider to 133 and start toying around w/ it. a good setting for you would probably be 260 x 10 @ ~ 1.5v (1.55v if you can). maybe there's a percentage increaser or something in your bios. i know in mine the max normal vcore is 1.4, then you can increase it by percentages.
Discussion Starter #15
im not sure..but i'll check umm...im not sure if i can get my ram on 133 cause the lowest is 200, i'll try these settings and brb...so i leave my HT @ x4
That MB can have amind of it's own if not all BIOS options are set correctly.<br />
<a href="http://www.overclock.net/faqs/38169-info-asus-a8n-sli-motherboard-introduction.html" target="_blank">http://www.overclock.net/faqs/38169-...roduction.html</a><br />
<br />
Dropping the RAM down manually to 333 is very common to allow head room for the CPU's OCing.<br />
Do you have a screen shot of CPU-Z "SPD" tab?
Discussion Starter #17
heres what i did..i did what u told me and its now 2.6, ram is on 333mhz..heres apic <a href="http://img299.imageshack.us/img299/9485/oc2pv6.jpg" target="_blank">http://img299.imageshack.us/img299/9485/oc2pv6.jpg</a>
don't shrink it <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /> can't read it.<br />
<br />
and now if you got to 2.6 Ghz, all you have to do is run superpi a few times and then run a few hours of prime95 (always best to run 24 hours to make sure you're stable). if you're not stable your computer will either A) lock up or B) randomly restart
"SPD" tab gives up the default info!
Discussion Starter #20
i resized the pic... and tried torun prime95 and halted once i started it..<br />
thats what my 2.5 Oc did too...but i was able to game ike i normally do..immarun 3dmark see if it locks up
1 - 20 of 42 Posts
