I have some problems to get the 1000MHZ gpu stable
I use the MSI Afterburner and my maxium is 995MHZ with 1,25Volt.
How can I set 1,3 Volt with the MSI Afterburner?
I set
UnofficialOverclockingEULA I confirm that I am aware of unofficial overclocking limitations and fully understand that MSI will not provide me any support on it
UnofficialOverclockingMode 1
but the maximum voltage did not change still 1,25Volt as maximum.
What did I wrong ? With the UnofficalOverclocking I can set the GPU to 1320 but this don't make sence without a higher voltage.
Do you have an idea to unlock the maximum voltage ? Or do you have some OC Bios ?
(sorry for bad english)
I set
