Hello everyone,
I unfortunately have come to a stand still.
First things first let me get my spec's out of the way.
i7 920 revision D0
EVGA E758-TR Mobo
OCZ Gold Memory (3x2GB) 1066mhz
XFX 6950 1GB
650Watt Modular PSU
240 watercooling kit (RS240)
I do understand my voltages may be a little high for the overclock.
vCore : 1.399
DRAM: 1.54
PLL: 1.875
QPI: 1.350
I originally tested the vCore at 1.5 in order to test temperatures under my watercooling. Maxed out at 71C.
Current OC Settings:
190fsb
21x Multiplier
17x Uncore Multiplier
Memory (Is very loose atm) (11-11-11-24)
Current memory is 1516mhz.
Current clock is 3980mhz
When I attempt to go over 190fsb the computer will boot to windows however immediately when running linx about 8 seconds into the test the computer will blue screen. I have been told this very well may be the memory which I at this point don't doubt. I set the memory to use ratio's 2:6 which then set the clock > 1100 ; however < 1200. I set manual timings of 11-11-11-24; if set to auto they set themselves at 7-7-7-18. Unfortunately I have the same exact result of blue screening even with the changes.
Any ideas?
i7 920 revision D0
EVGA E758-TR Mobo
XFX 6950 1GB
650Watt Modular PSU
vCore : 1.399
DRAM: 1.54
PLL: 1.875
QPI: 1.350
190fsb
21x Multiplier
Any ideas?
