Originally Posted by
AtomiS
Hi i whant to overclock my pc to speed up the gaming low frps every game i play the problem is that i dont now how to do it corectly so im asking for youre help i tryed 2 tutorials from the internet and i faield both so i dont whant to destroy my pc becouse im stupid
i whant to encrease the power to 3.2 Ghz stabel
This is my spec of the PC if you can pelase guide my exactly whant to do in bios please.
slot 4 is the same , slot 1 and 3 is empty.
Thx for youre help.
Click DEL when the PC turns on, go into BIOS, go to MB Intelligent Tweaker M.I.T. Then do this:
Robust Grahpics Booster: AUTO
CPU Clock Ratio: 10
CPU Host Clock Control: ENABLED
CPU Host Frequency: 320
PCI Express Frequency: 100
CIA 2: DISABLED
Preformance Enhance: STANDARD
XMP: DISABALED
(G)MCH Freq Latch: AUTO
System Memory Multi: 2.00
CAS Latency Time: AUTO
tRCD: AUTO
tRP: AUTO
tRAS: Auto
Load-Line Calibration: ENABLED
CPU Vcore: 1.250V
CPU Termination: 1.3
CPU PLL: 1.50
CPU Reference: AUTO
MCH Core: 1.150
MCH Reference: AUTO
MCH/DRAM Reference: AUTO
ICH I/O: AUTO
ICH Core: AUTO
DRAM Voltage: 2.00
DRAM Termination: AUTO
Channel A Ref: AUTO
Channel B Ref: AUTO
Any of the above settings missing? Just ignore them and continue
Also go to ADVANCED BIOS FEATURES and do this:
CPU Enhanced Halt: DISABLED
C2/C2E State Support: DISABLED
C4/C4E State Support: DISABLED
CPU Thermal Monitor 2: DISABLED
CPU EIST Function: DISABLED
Now go back to the Main BIOS screen and go to SAVE & EXIT SETUP, Press Y and let the PC Reboot. Should boot to Windows at 3.2Ghz
Let me know what happens!
(And yes i typed all that lol)
