Overclocking my Q6600
1071 Views 19 Replies 7 Participants Last post by  ericeod
I'm trying to overclock my Q6600 (note that I took it apart from a Dell), with the GIGABYTE GA-EP45-UD3R motherboard.
I was trying to go to 3.0Ghz to start, but even setting the vcore to 1.39 it still blue screened. Anyone know how this could happen?
1 - 20 of 20 Posts
The most common mistake people make when trying to overclock the 775 cpus is they forget about the ram. Double-check that your ram divider (or ratio, as some mobos call it) is underclocking your ram. And if your mobo supports it, leave all voltages besides the vcore on auto. That should get you 3.4ghz pretty easy.
How would I got about this? I have 800Mhz ram.
http://www.newegg.com/Product/Produc...82E16820231122
Set the SPD to 2.00B which is the lowest divider. That will keep the ram at a 1:1 ratio with your FSB speed. So if you set the FSB to 333MHz, the ram will be running at DDR2 667. Do this while OCing thew CPU, then go back to the ram and mess with it some more.
Edit::
You will also want to bump the NorthBridge (called MCH Core in Bios) voltage a little because of the 8Gb of ram. The default for the p45 chipset is 1.10v, but 1.20v is a nice voltage to run. it is not too high, and also works great for a 400 FSB - 445 FSB OC for most.
here is your entire bios for reference:
Look at this Overclocking guide: http://forums.legitreviews.com/about10789.html
We have great OCing guides here on OCN as well...
http://www.overclock.net/intel-cpus/...-core-2-a.html
here is a compilation of Intel OCing guides:
http://www.overclock.net/intel-cpus/...ed-guides.html
Well... it looks like even when I mess with those ram settings and vcore I still managed to bluescreen. Or maybe I'm just not messing with the ram settings enough.
Can you please post all your settings in the bios.
Have you read up on this thread?
http://www.overclock.net/intel-mothe...ers-guide.html
Here is a bios template. Replace the below info with your own bios settings
Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ...............: Auto
CPU Clock Ratio .......................: 9
CPU Frequency .........................: 3.24GHz (360X9)
Clock Chip Control
Standard Clock Control
CPU Host Clock Control.................: [Enabled]
CPU Host Frequency (Mhz) ..............: 360
PCI Express Frequency (Mhz) ...........: Auto
C.I.A.2 ...............................: [Disabled]
Advanced Clock Control
CPU Clock Drive........................: Default
PCI Express Clock Drive................: Default
CPU Clock Skew (ps)....................: 0ps
MCH Clock Skew (ps)....................: 0ps
DRAM Performance Control
Performance Enhance....................: Standard
Extreme Memory Profile (X.M.P.)........: Auto
(G)MCH Frequency Latch.................: Auto
System Memory Multiplier ..............: 2.00D
Memory Frequency (Mhz) ................: 720MHz
Standard Timing Control
CAS Latency Time.......................: 5
tRCD ..................................: 5
tRP'...................................: 5
tRAS...................................: 15
Advanced Timing Control
Everything In Advanced Timing Control on auto.
Motherboard Voltage Control
Load-Line Calibration..................: [Enabled]
CPU Vcore..............................: 1.34375v (= 1.312 in windows)
CPU Termination........................: Auto
CPU PLL................................: Auto
CPU Reference..........................: Auto
MCH/ICH
MCH Core...............................: Auto
MCH Reference..........................: Auto
MCH/DRAM Ref...........................: Auto
ICH I/O................................: Auto
ICH Core...............................: Auto
DRAM
DRAM Voltage...........................: 2.10
DRAM Termination ......................: Auto
Channel A Reference....................: Auto
Channel B Reference ...................: Auto
Advanced
S.M.A.R.T................................: Enabled
CPU Multi Thread.......................: Enabled
No-execute..............................: Enabled
C1E.........................................: Diasbled
TM2.........................................: Diasbled
EIST.........................................: Diasbled
Virtualization.............................: Enabled
Delay.......................................: [0]
Clock Chip Control
MCH/ICH
DRAM
Advanced
Thanks...After doing this...I just reset my cmos for the first time.
This is what I know I will be able to run on (currently)
CPU Frequency .........................: 2.40GHz (266X9)
Clock Chip Control
CPU Host Frequency (Mhz) ..............: 266
System Memory Multiplier ..............: Auto
Memory Frequency (Mhz) ................: 800MHz
CPU Vcore..............................: 1.35 (Auto)
MCH/ICH
DRAM
DRAM Voltage...........................: 1.80
Advanced
C1E.........................................: Disabled
TM2.........................................: Enabled
EIST.........................................: Disabled
If you don't like resetting the cmos then overclocking is not for you. That button is every overclocker's best friend.
When you bluescreen, when does it happen? Before you're done loading windows? A few seconds after loading windows? once you put a load on the cpu? I ask because BSODs can come from TEMPS aswell as low voltage.
Another way to overclock is to up the cpu 100mhz, load windows and stress-test. If its stable for 5 min, reboot and up another 100mhz. Keep doing this until you fail/bluescreen the stress test, then kick the vcore up by 0.1v and repeat. Remember you are overclocking the ram too when you change the FSB so ensure you're running the 1:1 ratio (link and sync mode).
Let us know how far you get (ghz, temps, and voltage), and we can help out with the other minor settings and voltages to reach the maximum oc
Well every time I've overclocked I haven't even gotten to the password screen. That time I had to reset the cmos (I pulled the battery out since I don't know if there's a button or not) it didn't even post after the Gigabyte screen it restarted.
sorry, i've been spoiled by my mobo (two reset buttons
). For you, it should be a 2-pin jumper near the bottom-right of the board. Your motherboard manual should also say where (page 7, i've heard).
If you're having trouble with any oc settings, try my one-step-at-a-time method
what is he using to cool it ? his sig rig doesn't say anything about aftermarket..
First let me ask.. what's your Q6600's vid? You can check your vid by downloading coretemp and opening it, there you'll see your vid. The reason I ask is Q6600s with high vid (highest is 1.325v) are generally poor overclockers.. my Q6600's vid is 1.325 and I really have trouble passing 3.2GHz... i currently have mine at 3GHz @ default vcore (1.325v) using:
333 x 9
CPU voltage: 1.325
MCH: 1.30
FSB Term: 1.30
PLL: 1.50
try those, but check your vid first.. maybe it'll explain why you're having a hard time
I had a q6700 back in the day... same vid, and i was able to hit 3.6ghz @ 1.55v stable
Clock Chip Control
MCH/ICH
DRAM
Advanced
Try setting the following:
CPU Host Frequency (Mhz) ..............: 333
PCI Express Frequency (Mhz) ...........: 100MHz
System Memory Multiplier ..............: 2.00B
DRAM Voltage...........................: 1.90v
MCH Core...............................: 1.22v
CPU Vcore..............................: 1.35v .. take it off auto
Originally Posted by nickkay View Post
It's 1.325v.
we have the same vid
i'm sorry to say, but you'll find it real tough to pass 3.2GHz.... right now im using my ASUS P5Q deluxe and am having a hard time stabilizing at 3.2GHz.. I used to be able to do 400x8 on my MSI P45 plat, but with this one I'm having problems. maybe you'll have to stick with 3GHz.
Right now he is only trying for 3.0GHz but cant get it to even boot when he changes his settings.
1 - 20 of 20 Posts
