1 - 4 of 4 Posts
Hello I´m pretty new in here, well registered since 1 minute
I have some questions about overclocking my system. Now here is the system:
Abit AA8XE with I925xe Chipset (droop modded) Chipset watercooled by a Leon rev. 102
P4 (Prescott) 3.6 HT (watercooled by an H2O Nexxxos Bold)
1GB Kit Corsair XMS2 DDR2 667MHz Pro Series
Asus Extreme X800 XT PCIe (watercooled by the new Nexxxos)
2 x Samsung Spinpoint P80 160GB in a Silentstar Watercooling Cage
watercooled Energy Device
Black Ice Extreme double radiators build in an Lian Li Pc6077 Alu Case
All that stuff pumped by an Eheim 1000 integrated in a Plexi Hull
So now comes the fun part. I wanna overclock that stuff to absolute maximum and need some help from real pro´s.
I did the droop mod because of the VCore stability. I need all the experiences that have been made with that stuff and on which Bios settings I can run it. The FSB can run up to 1066 MHz and I nearly wanna use it. I´ve heard of running the ram at nearly 857MHz and that the HT technology from Intel needs to be OC´d to get it´s full power. Can you guys help me get the rest out of this *****y little machine
Ok, read this guide carefully. Increase vcore, and loosen your ram timings.
Is your cpu:ram speed at 1:1?If not then set it to 1:1 for the best performance.
EDIT:WELCOME To THE FORUM!
1 - 4 of 4 Posts
