1 - 10 of 10 Posts
Storage Nut
Originally Posted by munaim1
It's downclocking when it's at idle because you have C1E and Sspeedstep enabled. Once you put the cpu under load the multiplier will go up. It's a safety feature that works as intended and nothing to worry about especially when it doesn't effect stability or overclocking.
This^ lol, didn't I already tell you?
Ready got a highr o.c.?
Discussion Starter · #8 ·
It's good for now! I used the OC preset in the bios which works excellent. I looked at it a little bit more and they have a preset of 4.7 GHz. included in the bios. I was like wow! This mobo is impressive.
Photo proof included!
Storage Nut
Nice...but I would try doing it manually...better control over the vcore.
1 - 10 of 10 Posts
