1 - 19 of 19 Posts
Hello guys, i am new in here ;]. Well i started enjoying overclocking after i bougt my athlon 2500xp barton AND then i said" i won't overclock it' 1,8 ghz is enough for me, but after a week, i overclocked it
... Hehe, now i i have 3200 xp.. But i didn't stop on that. And now i come to this part of overclocking, i WANNA boost up my granny, my old radeon 9000(128 mb, 128 bit, 250 core, 200 memo)... Well i tried to check max core, i used ati tool , and managed to boost it up to 310, but after then it could go on because of errors and artifacts (artifacts ar not visible), so i thought **** it, i need better cooling, well and today i bought "cooler master cool viva vga cooler", but i didn't attached it yet, i'll do it on saturday or sunday, but i am writting here to ask what should i expect from it?
p.s anyway i will use this cooler on the following cards, and hello to everyone
please give full pc specs.
Overclockiit
Welcome to the forums bro, as far as the cool master viva vga cooler i hope your gonna have enough room in your computer for it to fit thats gonna take up a pci slot, but i would say "ambient depending" that your temps should drop anywhere from 3-10 give or take with that vga cooler
Make sure to post back with results when you have hooked it up.
Discussion Starter · #6 ·
Yeap, mate
, i think thats pritty cool with my ambient in my pc case
, i've mod it abit
, and now my proc temp is max 40c, and other are low then 30, the only hot ***** in my pc is my vga
)), well but that will change soon.. i hope..
i would reccomend you up you AGP voltage up threw the bios to 1.6 and then use RivaTuner and up your core to 330 and your mem to 230 and try that!
Discussion Starter · #8 ·
Yep man, thnx, i will try your suggestions, but after i install this cooler, i forgot to say! that my old cooler on this vga is passive, and it is really hot.. REALLY
, and thnx for the suggestion about power it up, i'll surely try it.
wow lol dont do it yet lol, get a good cooler for it!
im still chuffed about my Radeon 9600 256mb Non-Pro ive got it fully stable at 450/250 froum 325/202!!
Discussion Starter · #11 ·
Yep man, but wouldn't mine cool viva help me a bit with it? I wanted to say that i will raise the power after i put it on, then i'll test it fully, so will this cooler stand this out?
the cooler will allow a better overclock i think you should get to 330/230 or a bit more, but if you dont have the cooler you gonna get artifacts quick becuase of over heating.
Discussion Starter · #13 ·
ok, well i'll probably do this tomorrow so i think i'll be able to do some serious testings on sat or sunday, but i will post it all here, for you to know
, i hope i get a little profit of buying.. anyway 20 $, hmm my card costs abou 30$
hehe
lol, have fun squezzing the snot outa you card! be careful it very addictive, you dont want to smoke do ya!
Discussion Starter · #15 ·
Hehe, i already saw that it is addicted
, why do you think i bought this cooler? But as far as i don't wanna burn it up, i try to hold my addiction
, but every time i run ati tool, i wanna boost it up to the max.. And i wanted to ask, whats the burning temp of vga proccesor? just curious..
i think its 80c, but dont let it get past 50!
Discussion Starter · #17 ·
hehe
lol, when i was testing, its core, when there where ~300 mhz temp was much more then 50 because, when i put common termometer on it it raised to 42 very fast, and as it is elevtronic it show " high"
well, hope new cooler will make a change for it. Here is fotos of old one and new one coolers :
old one : http://img94.exs.cx/img94/8679/041014_234859.jpg ; http://img94.exs.cx/img94/1897/041014_235110.jpg
new one: http://img94.exs.cx/img94/3042/041014_235618.jpg ; http://img94.exs.cx/img94/4241/041014_235757.jpg ; http://img94.exs.cx/img94/9049/041014_235815.jpg
Sorry for the quality, photos were took by a mobile phone...
nice cooler, where you get it from?
Discussion Starter · #19 ·
Ok, guys, i've put it on, well but that's not the problem
. When i turn my pc, while windows are loading, it shows me artifacts, the same is on bios. Hmm, what could it be? Well about overclocking max core 320~ and max mem 247, how far should i raise them? should i raise the power .. ?
P.s i bought it at pc store, for 20~ $
1 - 19 of 19 Posts
