1 - 4 of 4 Posts
I'm unable to oc my uncles comp at all, i know it's not very good but he wanted me to try get few extra mhz outa cpu but obo seems to be horrible lol. Only votage changes in bios works i try to raise it from 200fsb on it doesn't change in windows or even when i try to use easytune 4 or 5 no change what so ever.
Set up is
GA-K8VM800M I know he made bad choice.
2800+ 64 socket 754
512 smasung ram
450 watt generic psu = more then enuff
40gig drive
now mobo part it's crap lol onboard vid the works but not even easytune changing setting's is weird. It's a via chipset.
if it's a dell, then it probably wont be able to OC.
If not, then its probably the motherboard holding you back...it should hold the settings...weird..
CMOS battery ok?
Not a dell since it's amd 64 socket 754 but mobo well not hold a setting besides voltage not even with easytune since it's a gigabyte mobo.
I TeK things...
CMOS battery ok?
hateways do that too....tried to OC my mother-n-law's hateway = nogo
1 - 4 of 4 Posts
