Overclocking software
528 Views 8 Replies 5 Participants Last post by  Massive17
I'm trying to overclock my dads Athlon 64 X2 4800+ but he has some crappy motherboard that wont let me adjust bus speed in the BIOS, what are good programs that I can use to adjust frequencies and bus speed without going into the BIOS. The only things I can adjust in the BIOS is the voltage and the multiplier. -Art
1 - 9 of 9 Posts
try speedfan, or clockgen
I know it probably is **** compared to a lot of other free OC software, but AMD Overdrive seems decent to me, although IDK if you can get it, came with my mobo.
All he has to do it DL it from AMD
Thanks guys tried AMD overdrive but didnt work with the crappy mobo
You need an AMD 7-series chipset to use overdrive.
Try nVidia's control panel
clockgen doesn't let me change anything it just shows info
sorry I am a NOOB whats the PLL and where do I find it the mobo is Asus M2V-MX SE. Does CPUZ show it? I looked on the Mobo but cant find it
1 - 9 of 9 Posts
