1 - 6 of 6 Posts
i just put togather my new computer asus p5w intel e6700 core duo. i also have it on aircooiling the thermaltake silent tower. a very large heatsink i got it instlled with zalmant thermal compound. <br />
<br />
What i am wondering is i got it overclocked now to 3.3ghz stock is 2.6 and i run a cpu burn int test that runs it at full power and the max temp reached is 95 degrees F. and idle is uner 80 but usually 75-75 F. that temp seems very low i am using the pcprobe II by asus. it runs perfecty stable i have run 3dmark a few times played HL2 games and not a glitch. i was just wondering if that is a normal temp is my software reading low. i am going to try higher to see when it crashes.
convert your F temps to C temps ( (degF-32) *5/9 = degC) and keep it absoultely under 65 C.... that's when dammage is sure to happen. 50C to make sure of it.<br />
<br />
[edit]: 50C = 122F (so keep it under 120 for a round number). 65C is 149F (so under no condition should it go over 150F)
<tr>
<div>
Originally Posted by <strong>ae804</strong>
</div>
<div style="font-style:italic">convert your F temps to C temps ( (degF-32) *5/9 = degC) and keep it absoultely under 65 C.... that's when dammage is sure to happen. 50C to make sure of it.<br />
<br />
[edit]: 50C = 122F (so keep it under 120 for a round number). 65C is 149F (so under no condition should it go over 150F)</div>
</td>
</tr>
</table>
</div><br />
My E6400 ran fine for some weeks on 50C idle and 70C load. Replaced my old CNPS7000-Alcu for a CNPS9500 and now im under 40Cload <img src="/images/smilies/thumb.gif" border="0" alt="" title="Thumb" class="inlineimg" /> <br />
So its not that it breaks at 65C but it isnt good <img src="/images/smilies/redface.gif" border="0" alt="" title="Embarrassment" class="inlineimg" />
you don't want to run for a long time over 60*C
Those are really good temperatures you are running on the CPU. Use the Intel TAT program to get a more accurate reading and report back.
I remember when......
From what I have seen on my systems, PC Probe 2 is usually pretty close to TAT, within 3-5 degrees usually.<br><br>
That Silent Tower is huge, I thought about it for a while to use on my 920 but it got mixed reviews so i went with the NH-U12.<br><br>
What kind of fan(s) are you using on that Silent Tower and what is your ambient temp? Sounds like you are running around 35c full load, 65c on a Core 2 Duo is not good advice, especially an overclocked one unless you rarely use it at full load. 60c is the maximum recomended for a stock Core 2 Duo, 55c is best for a moderatly overclocked C2D, and if you are using lots of voltage, I would personally keep it under 50c or lower depending on voltage.
1 - 6 of 6 Posts
