1 - 17 of 17 Posts
I just got my EVGA 7800GS and installed it. This thing is sweet!
I am very new to all this overclocking stuff and was wondering if somebody would be kind enought to give me a laymans version of how to overclock my 7800gs. In addition to the card, I have a vantec card fan cooler mounted in the slot directly below the 7800GS for extra cooling. Not sure how much it helps, but its better than nothing
What are the steps to do this?
What program is the best to use?
What is the max speeds I should overclock to?
Thanks all!
Which EVGA 7800gs do you have? If it is the superclocked version there is very little room for overclocking.
Originally Posted by GatorLCA
Go to www.guru3d.com and download "Coolbits" and in your Clock settings in the nVidia suite you can "Detect Optimal Settings"...one click you overclocked
Yeah, but you can get a lot more out of your card if you do it your self and move it up by 5 and test it. I used detect optimal and put me at 485/1.15 than i did it myself and got it to 500/1.24 stable. It my take more time but if you want the most out of your card i would do it myself.
-Sparda
Discussion Starter · #6 ·
Im not seeing a Nvidia Suite... can you explain? I see Nvidia settings and allows me to change to high performance... or high quality. Not sure what that means...?
-Sparda
Hello. I was thinking about getting the card but want to get one that is the most overclockable and yours seems to be more overclocked than even the not yet available KO Superclocked model (at 490mhz core). What setup/cooling solution do you have with the card and what card model did you purchase? 500mhz seems unreal on the 7800gs!
After you run the coolbits registry mod, right click desktop>nvidia disply>your monitor. then there is a tab on the left called "clock frequencies" this is where you will overlclock.
Then use this giude to help you better OC the card.
I volt modded my EVGA 7800 GS and got it to 673/1600 stable. You have to ground VID4 for the core overclock, thatll put it up at 1.50 GHz. you dont have to do anything else for the core, just put a small wire from VID 4 to ground heres a link http://forum.guru3d.com/showthread.php?t=200420 follow the first picture there. As for the memory overclock, i did a pencil mod from vr-zone, but make sure that your core is G71 not G70 before you do either
I run @ 476:1.400 65degre when playing hard,stock at 430:1.300
I run on AGP 4X because my P4P800SE left me and I run my spare 845PSBT (that suck's) I use EVGA aplication, the fan speed is set at 100%, I will try at 480-490 on the core to see if it can take more, I enjoy lifetime warranty!!!
i got my rigg intel pentium 4 3.6ghz EE on asus p5p800 se with 2 gb ocz el plat 2-3-2-5 v2.65 external clock 804fsb ht 201 external clock and im freezing the pc near a vent its winter 20F or less outside i managed to get my 7800 gs co superclock to 501.4mhz core and 1450mhz memory no problem and idle is 31C and load is 38-41C instanty is gains heet put the case is getting cold outside air rines 3d mark 05 fine 06 fine and ntunes stablity test fine i also tighten timings on mem 2.0 cas instead of 2.5 got 6,505 in 05 with a 3.6ghz EE single core prescott cpu-z from 3dguru.com says 3618.4 mhz cpu 804fsb
the cold air from outside is a good idea in the winter makes killing people in cs:s so much easier and lachiesis razer 4000dpi g3 lazer mouse
use rivatuner to oc but if your not overclocking jst use utility to push fan to 100% and lock upon boot keeps cards cool my hands are freezing lol
1 - 17 of 17 Posts
