1 - 6 of 6 Posts
First of all I don't know if this is the correct place to put this....
Ok so today I've been trying to overclock my AMD A10-4600m APU, and finally I was able to overclock the GPU ONLY:
Now, I haven't done any benchmark tests at the moment since my laptop is running in a single channel configuration, and its slowing me down, I'm waiting for new memory to arrive, when It does ill do some benchmarks. What I've only done, ran BFBC2 in stock and overclocked and YES performance was increased.
For the CPU, I haven't found a way to overclock it.....
Originally Posted by RavirHeart View Post
You can use AMD Overdrive to overclock which can be found here:
http://majorgeeks.com/AMD_Overdrive_d5988.html
thank you I was using overdrive on 7 it wouldn't stick or save on reboot on 8 it did but on windows 8 games with buddah.dll wont load but on 7 they will so I must choose to either overclock with the ability to save and play fewer titles on 8 or play all the games i want on windows 7 but be forced to set the igp everytime hmm what to do what to do
1 - 6 of 6 Posts
