[B]Advanced CPU Features:[/B]
CPU Clock Ratio ................................ [21x]
Intel(R) Turbo Boost Tech .................. [Enabled] << Disabled
CPU Cores Enabled ............................ [All]
CPU Multi Threading .......................... [Enabled]
CPU Enhanced Halt (C1E) ................... [Disabled]
C3/C6/C7 State Support .................... [Disabled]
CPU Thermal Monitor ......................... [Enabled]
CPU EIST Function ............................ [Disabled]
Virtualization Technology ................... [Enabled] << Disabled if you do not use Vmware or Virtual PC Programs
Bi-Directional PROCHOT ..................... [Enabled]
[B]Uncore & QPI Features:[/B]
QPI Link Speed .............................. x36
Uncore Frequency .......................... (Always 2x memory Multi or 2x +1, 2x +2, ect - Higher means more Vdimm or QPI/Vtt often but can help stability) So try x20-22
Isonchronous Frequency ..................[Enabled]
[B]Standard Clock Control:[/B]
Base Clock (BCLK) Control ................ [Enabled]
BCLK Frequency (MHz) ..................... 166
PCI Express Frequency (MHz) ........... [100]
C.I.A.2 [Disabled]
[B]Advanced Clock Control:[/B]
CPU Clock Drive ..............................[800mV]
PCI Express Clock Drive ................... [900mV]
CPU Clock Skew ............................. [0ps]
IOH Clock Skew ............................. [0ps]
[B]Advanced DRAM Features:[/B]
Performance Enhance ...................... [Standard] << Extreme may be best
Extreme Memory Profile (X.M.P) ......... [Disabled]
System Memory Multiplier (SPD) ........ [AUTO] << Set x10
DRAM Timing Selectable (SPD) .......... [Manual] << Set expert, then set each channels main timings and cmd rate one by one
[B]Channel A + B + C
Channel A Timing Settings:[/B]
##Channel A Standard Timing Control##
CAS Latency Time ...................... 6
tRCD ....................................... 8
tRP ......................................... 6
tRAS ....................................... 20-24
Below values may be left in Auto, except set Command Rate to 1T
##Channel A Advanced Timing Control##
tRC ........................................ (Should be = tRAS + tRP or above for stability)
tRRD .......................................
tWTR ...................................... (Must be Write to Read Delay/Same Rank - (tWL + 4)
tWR ........................................ 5-12 (Odd # values likely will fail)
tWTP ....................................... (tWTP Must = tWR + tWL + 4)
tWL ........................................ (tWL Must be CAS Latency -1)
tRFC .......................................
tRTP .......................................
tFAW ......................................
Command Rate (CMD) ................ << Set 1T
##Channel A Misc Timing Control##
Round Trip Latency ...................
B2B CAS Delay ..........................
[B]Advanced Voltage Control:
CPU[/B]
Load Line Calibration ................. [Disabled] I use and suggest Level 1, but all up to you
CPU Vcore ............................... Auto or setting stock value may be fine, but it would be best to set yourself. Maybe 1.2-1.35V for 3.5Ghz
QPI/VTT Voltage 1.150v ............ This is key to ram, with 12GB you may need a bit more than with 6GB, plus we are going to try to keep the tight timings. So you may need 1.25-1.425, all up to your CPU
CPU PLL 1.800v ....................... Auto is fine
[B]MCH/ICH[/B]
PCIE 1.500v ........................... Auto is fine
QPI PLL 1.100v ....................... Auto is fine or you can try 1.14-1.2
IOH Core 1.100v ..................... Auto should be fine, but you may need 1.14-1.2
ICH I/O 1.500v ....................... Auto is fine
ICH Core 1.1v ........................ Auto is fine
[B]DRAM[/B]
DRAM Voltage 1.500v .............. Set 1.66, you may need more here with 12GB, but for now keep trying with this and increase QPI/Vtt instead. If that does not help at the max I listed above then this may need to come up, or we may need to redo your whole overclock in a different manner (Diff. CPU multi, mem multi, ect)
DRAM Termination 0.750v [AUTO]
Ch-A Data VRef. 0.750v [AUTO]
Ch-B Data VRef. 0.750v [AUTO]
Ch-C Data VRef. 0.750v [AUTO]
Ch-A Address VRef. 0.750v [AUTO]
Ch-B Address VRef. 0.750v [AUTO]
Ch-C Address VRef. 0.750v [AUTO]
