I can easily get the i7 to 3.77 with vcore of 1.225.
Multiple of 26
Bus at 145
Runs CPU burn for 10 runs. (I know it is not a long term stability, I will get to that later).
The thing is that if I try to bump up the bus to 150, it takes a lot of voltage to get stable - as high as 1.28. Which other settings should I be experimenting with? Should I be playing with multiple rather than the bus?
Second note. I am not sure what the VID is on this. Running CPUZ it has the v-core fluctuating from 1.06 to 1.18. Any ideas on why that is happening? I assume there is some power management thing going on (speedstep is disabled)
Thanks
Multiple of 26
Bus at 145
Thanks
