1 - 20 of 27 Posts
Hey guys, i have an amd 4400 X2 processor and I just purchased the Zalman CNPS9500LED Heatsink/Fan and I'm running at 2.6ghz at 1.52 volts stable. I want to be able to overclock to 2.7ghz but i'm afraid of highering my voltage because right now i'm at 42C idle and 49C full load on Prime 95. What settings do u guys think I need to overclock to 2.7ghz, including ram settings? Can anyone help?
Nice CPU! And a good HSF too! THe only thing that I can say for you o do is up your VCore a little bit, and then try and get your CPU up to 2.7Ghz. If you don't wanna try that, then I dunno.
Enjoy!
Your temps are quite low, so maybe you can push up the Vcore a bit. What are your ram settings now? (frequency, divider, etc)
Those temps are not low at all, maybe for a quick test or suicide run, but for everyday use, he shouldn't go much higher. My advice, is, make sure your heatsink is seated properly, add some as5, or change your airflow within your case (you should have more fans blowing out then in), otherwise, that may be your cap for your cooling.
i have the same CPU and im running 2.6ghz on a 1.4 vcore with prime stable. maybe you should try uping the fsb and leave the vcore where it is and test it out first.
Originally Posted by Pacman
you don't need to push your vcore in order to overclock... you can just push up the fsb...
Guys, he's already overclocked to 2.6ghz, i think he already knows this...He's just telling you that it took that Vcore to get there at those temps, which are pretty high, and asking what he needs to do to get a higher overclock without raising the vcore too much higher to get it stabile because his temps will be too high.
Discussion Starter · #8 ·
Well, when I lower my Vcore it fails Prime 95, and when I higher my fbs it fails the Prime 95 as well. I'm going to need more Vcore in order to overclock. I dont understand this, I am using Arctic Silver 5 and only a thin layer, I installed the HSF correctly and I have it blowing the air towards the back exhast fan which is the correct way of installing it. My ram settings is 183 and fbs is 237 at 11 multiplier. I dont have an HTT on my mohterboard to set so i dont deal with that. I'm still confused as to why my cpu is still running hot while at 1.52 volts. If it makes a difference, my cpu was at the same temperature as right now when it was 1.42 volts so i was able to up .1 volts. Any other suggestions guys? BTW i have the Thermaltake Tsunami Dream Case which has a big fans. Do you guys think I should change my multiplier to 10 and up my fbs some more and see if that makes a difference?
i guess what i was trying to suggest was to try and increase the fsb without increasing the vcore anymore than it already was...
if you did that you would have to up the FSB to 270. that would be a pretty big OC but it couldnt hurt to try.
Also, whats your room temp? that can really affect the CPU temp
It depends on the processor as well. I moved to the opteron as it was not easy to find dual core stability at 2.7+ Ghz and low voltages.
This is the number one reason I made the transition to the opteron as they handle lower voltages and can make a somewhat higher overclock. I can get a higher overclock but the voltage necessary to get there is not worth the increase of speed. The sweet spot for the processor is where it is all about and they are not all created equal. Even processors from the same fp batch are different on the overclock.
Stability is more important than high clocks or at least this is my impression. If I had that processor with that voltage necessary to make 2.6 and considering the cooler I would not move higher. I would clean the heatsink and reapply some good thermal paste to see if the posibility is too much paste or a poor application. Just a rice sized piece in the middle of the processor.
R
Make sure you're getting enough of the cooler room air into your case. If your case has little/no airflow, your ambient temp can be be 10*C and it won't help you much. To test, grab a normal desk/room fan and put it facing into your case, with at least the left door off, preferably both off. Then run your comp and see how your temps are. If you have lower temps, bad airflow is the culprit. Invest in some case fans and set them up for good airflow in your case. If the big fan doesn't lower your temps, try re-seating your HSF.
Also, when did you put on the new HSF? Because AS5 usually takes about a week to "cure". I noticed a 5*C drop after the week period was up. While curing, make sure your computer isn't on all the time, AS5 cures better if it has lots of cooldowns and heatups.
G/L with your OC
try this....up the vcore alittle...put a 266 divder on that ramm with a 2.5-3-3-7 with at least 2.8v ..fsb 250 with a multilpier of 11
...had almost that same setup...had same ram and a opty 175 which is opty's 4400+ on a msi neo2 plat mobo
If a higher overclock means that much to you, perhaps sell the Zalman and replace it with the Big Typhoon and a slightly higher cfm fan.
Discussion Starter · #17 ·
Well thanks for you effort to help me guys but i seriously give up on this overclocking business..... I spent over 2 grand on my rig, this motherboard costed me 270 when it was new and its suppose to be one of the best motherboards out right now especailly for overclocking but i seriously hate it. I've had so much problem with this thing that i can't explain it all to u in one post. People have been able to clock the 4400 to 2.8ghz at 1.45 to 1.5 volts and i cant even get this damn thing to run stable at 2.65ghz with 1.62 volts..... I spent 70 bucks on a new hs/f just to clock .1ghz more..... I tried 2.7 with a voltage of 1.62ghz and my motherboard just totally shut its functions down on me. I couldnt even enter the bios so i thought i was skrewed. So i had to take the battery out and reset the jumper on the motherboard. I'm just gonna leave it on 2.6ghz until a new AMD quad core comes out lol. I was thinking about taking it to water cooling but then i thought eh better not because i already spent 70 bucks on the best zalman hs/f and if i get water cooling i'm afraid of leakage and i have to mount the damn tank in the back of my case. But thanks anyways guys...
My but you don;t have HT frequency.....It's on the CPU configuration page. It is prolly set to auto. To get higher, drop it down to 1x
You should be able to get to 2.75 no problem with that HSF. vCore at 1.55 (actually, you set it at 1.5, and most asus mobos run it at 1.55).
Ram timings:
Set ram on a divider. Really low. Then make ur timings....lets go with 2-3-3-7. Tell me how it goes.
I have had exactly the same problem and I'm pretty sure that it's due to the rubbish motherboard. I too wish I had never bought this Asus and gone with the DFI Lanparty. I can't get my 4400+ past 245 FSB and I currently run my PC at 260 x 10 (DDR 217)
Craig
1 - 20 of 27 Posts
