So for some reason i cannot get ATITools to work for me on Vista Bus. 32bit. I've tried 3 different versions (0.24?, 0.26, and 0.27b4) and they all don't show the clock speeds (0.0 0.0). I go into scan for artifacts and i'm not sure if its working due to the temp's not moving (stays put @ 65c). So is this working right and should i put in my clock speeds? Or should i try another tool.
I've read that EVGA Precision works charms however without ATI tools how am i suppose to check for stability? At the moment i have EVGA Precision, RivaTuner, and ATITools installed. Any other options to scan for artifacts/check stability?
I have the same issue as you, i just benchmark with like the crysis mod, or 3dmark, just run a game play it if u have problems then you fix ur clocks its as simple as that. Hope it works for you!
Overclock.net
