1 - 6 of 6 Posts
Well i'd like to overclock, but there seems to be a few problems. first off here are the specs<br />
<br />
4600 x2 SKT939<br />
DFI Lanparty UT SLI board<br />
XFX 7900gt<br />
1gig (2x 512) of Corsair XMS<br />
Aspire(Apevia) 520w PSU<br />
Stock cooling<br />
<br />
Well heres the problem: the computer is currently running, but not at stock speeds. The memory is non Dual channel at 166mhz, when rated at 200mhz. I know how to change it back, but i had to put the divider in to keep the computer stable. I want the FSB : RAM at 1:1, but it doesnt seem to accept the DC very well. Im not sure if other people have the same problem but im just curious.<br />
<br />
The 4600x2 should be overclockable, and id like to mess with it. but first off id like the memory running dual channel and at stock speeds. <br />
<br />
<br />
Thanks
add more voltage to the ram for stability, also, loosen the timings
Are the RAM modules simular in default timings and do they have the same DDR rating?<br />
Some dissimular ICs can be a headach!
Most can take 2.8v safely.
1st use orange slots<br>
then enable memtest in bios and run a few loops<br>
wich bios are you using...?<br>
for generic ram i would advice the last official......4-06 if my memory doesnt fool me<br><br>
make sure you have all the 4 power conectors plugged in to the board......i saw a few older revisions that needed all 4 to work correctly<br><br><br>
good luck
1 - 6 of 6 Posts
