**NOTE: I'm not responsible for ANY damage caused.
NEVER EVER EVER EVER OVERCLOCK AFTER 333 = no psp
Sony has confirmed that 333 is the top you should go. **
This doesn't work on ALL psps, but it's worth a try.
First, power it on.
Hold down R1.
You should see a console like thing.
This is in short computer terms BIOS for your PSP. [Recov mode]
Note: This can never be changed back.. EVER!
Go to CPU Speed ->
XMB = Memory Card
UMD/ISO = Disc in the PSP.
They should be set as Default.
Go to the one you like, and press X.
Note: DO NOT OVER CLOCK BY MORE THAN 333MHz !! Most psps can go up to 366, but that's a battery eater..
Go back.
Press exit. [NOT TURN OFF!]
Now you should be at the main screen.
Go to the card/UMD.
The game should load a heck of alot faster.
This doesn't speed up the game play. It just reduces lag and allows things to load much faster.
For example, if im playing Vice City, mission cut scenes will take less time to load. Vehicles will appear faster, etc.
If you have any problems, let me know.
Also, when your in recov mode, don't touch much else, unless you know what you're doing.
I recommend 300.
However, if your big on performance, and don't give a dang about your battery, i'd go 333MHz tops.
PLEASE let me know how it goes!
First, power it on.
Hold down R1.
Go to CPU Speed ->
XMB = Memory Card
Go back.
Go to the card/UMD.
I recommend 300.
