Overcloking my 8GB of DDR2 Patriot Viper PVS24G6400LLK
2100 Views 4 Replies 2 Participants Last post by  01s0uljah
I'm running a Intel Core 2 Quad 6600 2.4Ghz, ATI Radeon 4850 and 8GB of Patriots Viper PVS24G6400LLK Ram..
I want to give my ram a little kick.. Its running at the stock 2.1v voltage.. But I dont know what to do from here on to push it a little harder,... What settings would I have to change in the BIOS? the stock timings are 4-4-4-12.. I've looked around the board to check out others but not too clear on this..
1 - 5 of 5 Posts
Please fill out your system specs. Its very hard to help you out when we dont know what motherboard you have.
To enter system specs.
Click on User CP on the black toolbar at the top of the webpage.
Click on Add System under System Info.
Fill out everything you can. The more info we have the better.
updated! thanks!
Originally Posted by 01s0uljah View Post
updated! thanks!
Thank you.
Is your CPU overclocked at the moment or are you just trying to OC the RAM right now?
Edit: I dont know much about your motherboard, so hopefully someone can come along and help. In the meantime there is a thread dedicated to your board, so I would check that out.
Gigabyte guide.
Anybody else have any suggestions? I've read that I need a 1:1 ratio with my FSB.. which is currently at 266 *9 to achieve the stock 2.4 on my Q6600.. If I want to overclock my ram to 1066.. That would mean I have to change my multiplier to 4.5 x 533mhz in order to overclock my ram?
WHen do i adjust the voltage and the timings? Still confused here
1 - 5 of 5 Posts
